Luke Fleming, with help from Josh Leask of 86Drift Tuning, tapped his RaceCapture/Pro right into to the firehose of CAN bus data on his Toyota 86. Now he has steering angle, brake pressure, oil and coolant temperature, throttle position, RPM and wheel speeds – all using the direct CAN mapping capabilities of the RaceCapture system. Special thanks goes to Michael Karr as well for providing CAN bus details on the ’86. It’s all the result of on-going research on our forums – join us there for testing if you have an ’86 or BRZ. But first, check out the video!
