RaceCapture/Pro MK2 Production!
Robots building circuit boards, BECAUSE RACECAR
We’re cranking out the RaceCapture/Pro MK2 production! Last week we built a large lot of telemetry module; this week we’re building panel after panel of RaceCapture/Pro MK2 units. Here’s Brent with the first official panel built!
Brent_with_RCP_MK2_first_panel_out_of_reflow
Parts Feeders Always be Feeding!
All in all, Brent Scott, Kelley and Jeff were keeping the Lab warm along with the reflow solder oven. As typical with a new production run we had hiccups getting the pick and place machine fully dialed in.  The secret? It’s all about the feeders.  Here’s we’re either fixing a feeder or stringing a new reel of components onto one of the many feeders.
jeff_brent_fixing_feeder
Once the machine was dialed in, we could stage the RaceCapture/Pro MK2 panels for assembly. In this configuration, we can build 4  RaceCapture/Pro boards at a time. Note the big “waffle tray” behind the panel- this is the parts tray for the main processor!
RCP_MK2_panel_ready_to_assemble
Solder Paste and Rework
The first panel out of the pick and place (before solder reflow) gets a bit of re-work. Turns out the biggest challenge was getting that big processor soldered correctly. Too much solder paste = bridged pins, so getting the solder paste on the board perfectly will save tons of rework time.
RCP_MK2_panel_rework
Once we dialed in the process we’re able to get the boards cranked out. Here’s a few, staged up for the final through hole (bottom side) soldering process
RCP_MK2_ready_for_batch_soldering
