Some small but important fixes
You probably already have this version installed from iTunes / Android / Amazon app store – but double check to make sure, and update if necessary.
No Data? Yes Data!
In the last release, we introduced a problem where sometimes a gauge would show “No Data” for a channel, even though data is actually present. We’ve fixed this in 2.10.7
Saving files on iOS
We’ve fixed the location where iOS saves files, making it possible (again) to fetch files over USB when connected to MacOS. When you export a file, you can fetch it by going to Finder, selecting your iOS device, and then go to Files. There you’ll find your saved configs and exported logs.
Fixed copying of app log
The “Copy Log” button is very useful for getting the current log from the app to use for troubleshooting issues. This was also broken in 2.10.6 – so we fixed it here as well.
Available on all platforms. Seriously.
The RaceCapture app runs basically everywhere. Download links:
Android: Download from Google Play
iOS: Download from the iTunes App Store
Amazon Fire: Download from the Amazon app store
Windows: Download Direct
OSX: Download Direct
Linux: Download Direct
Raspberry Pi: Download Direct
Full Changelog
==2.10.7== Fix incorrect "no data" issue with gauges after device connects Improve lap de-selection performance for analysis Fix where files are saved on iOS Fix error when copying app log to clipboard ==2.10.6== Fix incorrect touch targets on certain mobile form factors ==2.10.5== Improve video and graphic rendering performance on slower devices via new framework Improve wifi connection reliability Improve reliability of received data from device to avoid corrupted messages Fix checking of exitstatus for raspberry pi Fix fullscreen setting problem on raspberry pi Simplify launch for Linux distributions by only launching race_capture vs script Switch to debian package distribution for Linux x86_64 Pre-create export directories for certain Android platforms to avoid error Fix error editing an existing session that does not have associated video Ensure gauges show 'no data' when referencing missing channels ==2.10.4== Improve telemetry connection by using new framework Fix file browsing for iOS when browsing for files other than images Fix possibility for status view errors ==2.10.3== Fix numeric input fields on Android Fix issue viewing script window on Windows when device is not connected Ensure analysis timegap chart shows useful data under all conditions Fix analysis line chart sometimes showing "No distance data / no time data available" Fix incorrect error message when pressing cancel on save/export dialogs on desktop Fix obscured / hidden controls on setup pages Fix double save confirmation on desktop builds Fix blank digital gauge when current value is 0 or not yet updated Fix typo in popup ==2.10.2== Add/Update APNs for EIOTCLUB, Rogers and Bell for Canada Fix Filebrowser for Raspberry Pi Fix linechart zooming when window is maximized Fix interaction with toggle button Fix possible error when deleting a CAN mapping Enable native file browse / save dialogs across all platforms ==2.10.1== Fix file permissions for Android ==2.10.0== Add text enumerations for digital gauges Add bitmap gauge Use native file pickers Improve telemetry connection recovery when network is interrupted Ensure trackmap is centered in cases where GPS trace is out of bounds
