(Picture courtesy of Happy Cactus Racing)
We’re listening! RaceCapture app 2.10.6 is all about important fixes, reported by you. By the time you read this you may already have it on your Android, Fire, or iOS device.
WiFi Connectivity fixes, especially for iOS
Looks like Apple iOS made a change that caused newer iOS devices to not connect to RaceCapture via WiFi. In the course of fixing this issue, we also improved the general stability of the data connection across USB, WiFi, and Bluetooth.
Improved performance on slower platforms
We’re using a new app framework that bumps overall app performance, especially for video and graphics rendering performance. We were pleasantly surprised to see this improvement! Always a great bonus to see when we upgrade.
Raspberry Pi Fixes
Did you have app problems on the Pi after setting full-screen mode – even though you were already full-screen, hoping to defy physics and get more than full-screen? Yes? Well, we fixed that too. Setting full-screen mode doesn’t magically make it more full-screen, but the app also doesn’t crash.
That ‘exitstatus’ error message on the Pi launch script was also fixed.
Linux package change and simplified launch
The Linux distribution is now delivered as a standard Debian package, so it can be easily installed on Ubuntu and similar distributions. You can now install it via the command:
sudo dpkg -i racecapture_linux_x86_64_<version>.deb
And then launch it as :
/opt/racecapture/race_capture
Many more improvements!
Check the Change Log below to see all the fixes included in RaceCapture app since 2.10.4 (we rolled 2.10.5 and 2.10.6 versions together)
Available on all platforms. Seriously.
The RaceCapture app runs basically everywhere. Download links:
Android: Download from Google Play
iOS: Download from the iTunes App Store
Amazon Fire: Download from the Amazon app store
Windows: Download Direct
OSX: Download Direct
Linux: Download Direct
Raspberry Pi: Download Direct
Full Changelog
=2.10.6== Fix incorrect touch targets on certain mobile form factors ==2.10.5== Improve video and graphic rendering performance on slower devices via new framework Improve wifi connection reliability Improve reliability of received data from device to avoid corrupted messages Fix checking of exitstatus for raspberry pi Fix fullscreen setting problem on raspberry pi Simplify launch for Linux distributions by only launching race_capture vs script Switch to debian package distribution for Linux x86_64 Pre-create export directories for certain Android platforms to avoid error Fix error editing an existing session that does not have associated video Ensure gauges show 'no data' when referencing missing channels ==2.10.4== Improve telemetry connection by using new framework Fix file browsing for iOS when browsing for files other than images Fix possibility for status view errors ==2.10.3== Fix numeric input fields on Android Fix issue viewing script window on Windows when device is not connected Ensure analysis timegap chart shows useful data under all conditions Fix analysis line chart sometimes showing "No distance data / no time data available" Fix incorrect error message when pressing cancel on save/export dialogs on desktop Fix obscured / hidden controls on setup pages Fix double save confirmation on desktop builds Fix blank digital gauge when current value is 0 or not yet updated Fix typo in popup ==2.10.2== Add/Update APNs for EIOTCLUB, Rogers and Bell for Canada Fix Filebrowser for Raspberry Pi Fix linechart zooming when window is maximized Fix interaction with toggle button Fix possible error when deleting a CAN mapping Enable native file browse / save dialogs across all platforms ==2.10.1== Fix file permissions for Android ==2.10.0== Add text enumerations for digital gauges Add bitmap gauge Use native file pickers Improve telemetry connection recovery when network is interrupted Ensure trackmap is centered in cases where GPS trace is out of bounds
