By popular request, we’ve added a string potentiometer sensor to our catalog of sensors.
This sensor is commonly used to measure steering angle – see our original blog post about how to set up a steering angle sensor in 30 minutes. However, It’s not just for steering angles – you can also use it for other linear measurement tasks.
Order today from our dealer network
It’s a compact and lightweight device and easy to mount to your vehicle.
Specifications:
- 10K ohm range
- 500mm stainless steel draw cable
- 2 meter cable
- M8 3P connector, works with our plug and play harness system
What other uses would you use this sensor for? Let us know in the comments!
