Our new linear temperature sensor requires no pull-up resistor and has a simple 10mV/C temperature response, great for CAN bus mapping as well as direct sensor integration.
Order through our dealer network
You can use the convenient preset for RaceCapture/Pro inputs – just 3 wires and you’re set.
If you’re using AnalogX, use the conversion formula in our wiki
Mechanical
- Thread pitch: 1/8″ NPT
- Body: Stainless Steel
- 13mm (1/2″) hex head
- Wiring: 18″ flying leads
Electrical
- Voltage supply: 3-5V
- Wiring color codes – Green: Ground; Red: 3-5V; Yellow: Signal Output
- Pull-up resistor: None (Active element)
- Operational temperature range: -40 to 150C
- Calibration: Linear response 10mV/C; 0.5V at 0 degrees C
