Note: Megajolt/C is a canceled project and there are no plans, present or future, to complete it.
The Megajolt/C is our next generation crank fired ignition system specially designed to work with the latest in ignition coil pack technologies. What sets Megajolt/C apart from other designs is the absence of built-in coil drivers: by moving these high-power drivers to external modules, we’ve been able to shrink the form factor while providing 8 flexible coil control channels, capable of a variety of ignition configurations:
- Crank-Fired Wasted Spark for 4,6,8 and 12 cylinders
- Crank-Fired Sequential ignition for 4, 6 and 8 cylinders
If your engine can drool
If you’re running distributor based ignition, especially old-style points, you’ll treat your engine to the following benefits:
- Overall improvement in engine smoothness and drivability
- Stronger spark throughout the RPM Range, especially at higher RPMs. Stronger Spark = more efficient burn = more power.
- Improved idle stability
- Full tunability with up to a 16×16 ignition map
- No mechanical parts (rotor, cap) to wear out
- No plug wires to replace (if running coil-on-plug modules)
If you’re already running a Megajolt Lite Jr / Megajolt/E you will want to upgrade only if:
- You’re an early adopter and like playing with the latest tech
- Your engine’s redline capability is beyond EDIS capabilities (about 8000 RPMs for EDIS-4, 7300 RPMs for EDIS-6; 6300 RPM for EDIS-8)
- You need and/or have a burning desire for true sequential ignition
Finally, you’ll benefit from the features you’d come to expect from a modern piece of tech:
- Powerful 32 bit ARM processor
- USB connectivity
- Bluetooth expansion (details below)
It’s all in the Name
The C in Megajolt/C stands for ‘Coil On Plug’. Meaning, it’s designed to work with coil packs having built in drivers (aka ‘igniters’). These coil packs first appeared on engines produced around year 2000, becoming commonplace on recent models. Often implemented as ‘coil on plug’ modules, such as the units found on the Toyota 1ZZ-FE engine (Corolla, MR2) , they also appear in the ‘coil near plug’ form-factor, as found on the GM LS1 engine, seen on the Chevy Camaro and Corvette. European manufacturers such as BMW, Mercedes and Volvo have their own implementations as well. With these modules becoming cheaply available in automotive wrecking yards and brand new from automotive parts suppliers, the time is ripe for an ignition controller designed to take advantage of this tech.
Crank-Fired and Cam Synchronized
To compliment the 8 coil driver outputs we included a dual VR sensor input- one for the crank and one for camshaft synchronization. If both are used, Megajolt/C provides true sequential ignition for for 4,6 and 8 cylinder engines, benefiting high RPM applications.
Dwell is the period of time the coil pack ‘charges’ before the spark plug is fired. In order to produce optimal spark energy, sufficient dwell time is needed (approximately 3-4ms). Since available Dwell time is inversely proportional to engine RPM, having sufficient Dwell time at high RPMs is critical, as this is when the engine is producing maximum power!
The following table illustrates available dwell time across different ignition system technologies:
Type | How often does the coil fire? | 5000 RPM | 7500 RPM | 10,000 RPM | 15,000 RPM |
Distributor | Every 180 degrees | 6ms | 4ms | 3ms | 2ms |
Wasted Spark | Every 360 degrees | 12ms | 8ms | 6ms | 4ms |
Sequential | Every 720 degrees | 24ms | 16ms | 12ms | 8ms |
Max theoretical available dwell time per cylinder (4 cylinder application) |
Note: The actual available Dwell Time is somewhat less due to processing overhead present in the Engine Management System.
As you can see, full sequential ignition is best suited for very high revving engines; For wasted spark, take comfort that this configuration is good to about 10K RPMs.
Bluetooth Integration
It kind of smacked me in the head when I was kneeling next to our Merkur XR4Ti at a race, frantically making an adjustment to the engine management system using my ‘compact’ laptop. The screen was hard to see, I had no table to set it on and the cable was too short. As a result, I had to squat on the ground, laptop perched on the floor of the Merkur, and shield the screen with my hands while trying to use the touch pad and keyboard. Ridiculous!
In my annoyance I realized there was a much better way, using the incredibly capable Android device I had stuffed in my pocket. Of course! The system should’ve had Bluetooth embedded- with wireless integration to my smartphone. I could whip it out, make a few adjustments on the easy to hold, easy to see, and easy to use form factor and off I would be.
Expanding on that- imagine the following capabilities with your smart phone or tablet:
- Full control over settings – ignition map, options, configurations- etc.
- Interactive gauges / dashboard. Put a suction cup mount on the windshield and gain an instant heads-up display!
- Datalogging and tuning to your heart’s content. No need for the hardware to have an SD card slot: It’s all possible your smartphone / tablet.
Due to cost, we felt that bluetooth integration should be an option- so we’re including a header on-board to receive an add-on board with an embedded Bluetooth transceiver. Cool!
Inputs and Outputs
Aside from the minimum inputs for proper functionality, we’ve added some extra features to make a well rounded system.
Sensor Inputs
- On-board MAP sensor: The same on-board MAP sensor used in existing Megajolt variants is a proven, cost-effective solution compared to expensive OEM modules.
- Throttle Position Sensor (TPS): For measuring approximate engine load when it’s inconvenient / impossible to get a stable vacuum reading (e.g. using bike carbs)
- Temperature Input: A coolant temperature sensor input for correcting ignition advance during engine warm-up period.
- Aux input: An extra analog input for.. future expansion (e.g. work with an external knock sensing module)
Option Input
As with existing Megajolt variants, the Option input will be used to switch between ignition maps on the fly.
Programmable Output
One programmable output is provided to drive an accessory device, triggerable on RPM, load, or other sensor value (1A capable)
Shift Light
A programmable shift light output is provided, which can directly drive an LED or small indicator lamp (1A capable)
Tach Output
A 12V pulsed output is made available which can drive a variety of OEM and aftermarket tachometers
Bonafide Vaporware
As of this writing we’re fabbing out the Revision A PC board. What’s great is the form factor will fit the existing enclosure we use for the Megajolt/E. Here’s an idea of what it will look like:
In a few weeks time we will have buildable-testable boards in-hand. Keep an eye on our forums for the latest news!
That is some serious shizzle going on there Brent!!
Let me know when it’s available, I will have funds ready to rock n roll!!
Thanks, Rich! Development boards are now in. Just need to get some time at the pick n place machine 🙂
What range will pricing be in?
I’m looking forward to sporting the Megajolt/C Brent. I’m excited!
Hi!
Been folowing your improvements since the original megajolt and I hope I can fit the new megajolt/C in my classical Renault 4 and Datsun 1200. So Im waiting for it …
But as a fan I have to make a sugetion as its on your site: I also have 2 70s vespas and I was miself tryng to work with an electronic engineer to try to make a simple module only to have variable timing ignition, wich ill probably be a hard task to start from scratch. But since your sistem is very complete and developed I can sugest you to make a new variant of it: smaler, simpler for 1 or maybe 2 cilinder and 2Stroke motorcycles – apling a sistem based on the waisted spark. I think it would have a lot of market, at least around europe. I live in portugal and I started a company of car obd tunning, turbos and have made some inexpensive improvements in converting maf sistems to a more reliable ones. As you can see I apreciate your work and spirit and wold be very pleased to make tests for you if you need any help. My main goal is to reduce my vespas consumption even more and get a bit more flexible engine in wich your sistem would be very important, but if you need I could also buy more kits to help justify your investiment.
Thanks for your time reading my words
Luis Lopes
Portugal
Hi Luis,
Thank you for the comments!
Yes, we are actually looking at a simplified system for 1 cylinder motors. it seems there’s interest around this application. Simple, compact, tunable, and hopefully waterproof would be the primary features.
Thank you!
Sounds very promising. How is development progressing and when will it be available? Also indication of price?
Regards
Charles
Keep an eye on the forums for the latest news- we’re close to testing the firmware on a live engine- we’re hoping for beta testing this year!
Thanks for your interest,
Hey,
Love this idea! Do we have a release for this?
Cheers,
Adam
Australia
Hi Brent.
Just wondering if you were still working on this. I just started building a twin carb Honda autocross car, and would love to do a coil on plug setup. There’s a bolt on cam sensor for my engine, and CBR1000 coils fit perfect, but there’s no box to make them talk!
Any updates? Can’t find anything in the forums.
Cheers,
Nathan
It depends on the ECU support of the car, but most log basic information like: RPM, Engine Temperature, Throttle Position
Definitely interested in this for my race car (440″ SBF, runs on methanol). I have not seen anything regarding availability, etc as of yet. Any updates?
Did you see the comment in red at the top of this blog post? 🙂
