Got a RaceCapture/Pro and an E46? We need your help! The 2.8.7 release of the RaceCapture/Pro firmware adds an important feature which lets us extract CAN bus data at a more detailed level. This unlocks a number of additional telemetry channels for the E46, including individual wheel speeds, fuel level, brake, clutch and more.
We need your help to test our updated script and verify the channels work as expected!
All the channels
All in, we’ve mapped 15 known channels:
- Throttle Position (TPS)
- Engine Temperature (EngineTemp)
- Oil Temperature (OilTemp)
- Engine RPM (RPM)
- Steering Angle (Steering)
- Brake Switch (BrakeSw)
- Brake Pressure (Brake)
- Clutch Switch (Clutch)
- Left Front wheel speed (LFWheelSpd)
- Right Front wheel speed(RFWheelSpd)
- Left Rear wheel speed (LRWheelSpd)
- Right Rear wheel speed (RRWheelSpd)
- Gearbox Temperature (GearboxTmp)
- Fuel Level (Fuel)
- Exterior Temperature (ExtTemp)
Some channels we have yet to verify, and we think it may vary by the particular E46 model. Specifically Brake Pressure and Gearbox Temperature are two channels that still requires confirmation – if you see data for these channels, please let us know the year / model of your E46 so we can note it!
How to test
Assuming you already have your E46 CAN bus integrated with RaceCapture/Pro, you just need to follow a couple of steps:
- Update your firmware to 2.8.7. Be sure to save your config before upgrading!
- Update your mapping script with our expanded channels script – just download or simply copy/paste the text (ctrl-a / ctrl-c). This script will enable the additional channels.
Once updated, drive around, log some data or just watch the dashboard. Comment here or email us what channels work or don’t work, and include the year / model of your E46!
Hi I have e46 m3 abs as a standalone in my car (not an e46). If I use this code do I need to delete out non relevant lines or will the system just ignore them because there’s no corresponding data packets?..
Hi! No, you do not need to change this script for an E46 M3, it will all ‘just work’. If there isn’t any data for the CAN ids that this script is looking for, it won’t output data for those channels. Everything else will work.
I have an E46 and RaceCapture/Track. Will this script work on my version of sw?
Wow, ancient article! Fortunately, the E46 no longer needs a Lua script; we now have direct CAN integration with RaceCapture. See the guide here: https://wiki.autosportlabs.com/BMW_E46_CAN
There’s a higher level related BMW E46 guide here as well.
https://wiki.autosportlabs.com/BMW_E46_Guide
Thanks Brent, so glad to see you have it monitored! I’m new to all this and will be digging into whatever I can find that’s the latest. I’ll read through the guides you sent. Quite helpful!
Great! Please join one of our communities (Discord / FB group / Forums) and we’ll be happy to help more. Thanks!
