The CoilX sensor module is designed to safely convert the noisy, high voltage RPM signal present on most ignition systems into a clean RPM signal for RaceCapture/Pro or other hardware devices. It’s a tiny, lightweight sensor module that can be quickly soldered with 5 wires and bundled seamlessly into your wiring harness. Available now in our online store!
