Autosport Labs is excited to announce the next generation of motorsports data logging: RaceCapture/Pro 2! We’ve been hard at work for the past months making this the best data logger and live telemetry system available anywhere.
Incredible New Features:
Directly connect a CAN-enabled OBD-II port
You can even power RaceCapture/Pro from the OBD-II port – it’s plug and play! (2008+ ECUs, 1997-2007 with external adapter)
Two CAN channels = massive expansion
- 4 wheel tire temperature sensors
- 4 wheel tire pressure sensors
- Per-cylinder EGT… and more!
7 Axis Accelerometer, Gyro and Compass
- Analyze car dynamics using the advanced 6+1 axis accelerometer, gyro and compass.
- Measure under and oversteer conditions
- Compare shock, spring and swaybar adjustments
50Hz GPS Technology
- Take advantage of the latest GPS technology
- True 50Hz GPS performance – not simulated!
- Enjoy finer grained analysis, with automatic down sampling for real-time telemetry
1000Hz sample rate: standard
- Did we say powerful? 1000 samples per second enables measuring shock travel and other high speed sensors
- All channels can be sampled at individual rates, and automatically downsample for telemetry
- With suspension travel sensors it’s like a 4 wheel shock dyno, right on the track!
Over 3x more horsepower
- Telemetry data with real-world values – no post-processing needed!
- Create custom Virtual Channels that process on the fly
- Far more powerful than the “Maths Channels” found in other systems
- Calculate gear position, efficiency ratios, and more
- On-board Lua Scripting lets you control warning lights, fans – even Active Aero!
Beautiful, touch oriented app
- Leave the laptop at home and do it all trackside from your tablet or phone!
- Dashboard: watch lap times and sensor data
- Analysis: Analyze telemetry and compare laps
- Configuration: Calibrate sensors, sample rates and more!
Real-time telemetry: Built in!
- Designed from the ground up for cloud-connectivity, the internal telemetry option makes for a simple, all-in-one installation.
- Future Proof: take advantage of the latest cellular technology with the upgradeable internal module
When are you guys ready to release this? Hoping to put this in o er the winter and ready for next season.
Hi Alex, here you go: http://www.autosportlabs.com/racecapturepro-mk2-launch-target/
